Tried out new patch.
I set the Simulate label/text on the
DualPane3AxisCode(AUTO) screen to UnCheck the Simulate
checkbox. Then set the Simulate label/text on
DualPane3AxisSplit(GRAPHICS) screen to Check the Simulate
checkbox. Both are working as they should when i
navigate/load screen, but, there is a Kmotion window that
pops up stating "Enter a Number." with an OK button. Once
i click OK pop up window goes away.
I used the KmotionCNC.exe from Patch folder FixCheckboxMesg_40SpareEdit_EditPersists_V434i
and all of other files from Patch folder
AddScreenScriptWinMsgPersistTextCopyPasteV434i.
Did i use a wrong file?
Troy
"Troy/Tapio/Others,
Here is another Screen Editor Patch
http://dynomotion.com/Software/Patch/FixCheckboxMesg_40SpareEdit_EditPersists_V434i/KMotionCNC.exe
Fix issue with Action Messages to Checkboxes
checking/unchecking
the checkbox but not changing underlying variable.
Persist Edit Controls between sessions. Saved to
<>\KMotion\Data\EditControlPersist.txt
Increase number of spare edit controls from 20 to 40
Please let me know if there are issues.
TK"
Hi Troy,
for the good description. Seems like
Checking/Unchecking the control doesn't change the
underlying member variable that effects other
functions. And maybe another bug. Give us some time to
look into it.
New screen edits is looking great. Can see the
potential with it. :)
Here is what i tried to do on my desktop PC
with no KFLOP installed.
On my Graphics Screen(DualPane3AxisCode.scr) i
set the Simulate Label to check simulate box.
Then on my Auto Screen(DualPane3AxisSplit.scr) i
set Simulate label to UnCheck simulate check
box.
When i go to Graphics screen the Simulate check
box is checked but axis DROs are still yellow.
Once i click the simulate Run button the G
viewer shows the simulation and after this the
axis DROs turn white.
Next i go to my Auto screen and axis DROs are
still white and when clicking Play/CycleStart
button nothing happens. I would expect to get a
pop up stating i dont have a device connected.
But it appears that the simultae mode is still
active. After this i closed KMotionCNC and
Screen Editor and launched KMCNC. Tried to see
if toggle state would go off and still will not.
Once i launched Screen Editor i got a KMotion
pop up window stating "Invalid WinMsg Message
Code:BM_SETCHECK".
After clicking OK i get a KMotionCNC pop up
stating"Error Sending Screen Load Label
Action/Script/WinMsg. ID:IDC_SimulateStatic
WinMsg:DlgName:IDC_Simulate:BM_SETCHECK;BST_UNCHECKED"
Should i be doing this another way?
Attached is screen shots of my custom screens.
Troy
Hi Troy,
look into it.
box.
Code:BM_SETCHECK".
Troy
Hi Troy,
look into it.
box.
Code:BM_SETCHECK".
Troy
